i have a 91 honda accord it starts but when i try to drive it i have to hold the gas to make it go and when i stop i have to do it again
Extract any check engine light codes and post them here. Your local parts store will do this for free.
If the idle seems low when in park as well, I recommend cleaning the inside of the throttle body throat and the edge of the butterfly. Do not spray in the throttle body. Spray starting fluid a rag a wipe. This should increase the idle and may take care of the issue when in gear.
If it is still troublesome the IAC – Idle Air Control Valve (Idle Speed Control) may need to be replaced.
