I have a dodge truck with a 318 and I had to replace the manifold and rocker cover gaskets and now it wont start
I previously replaced the spark plugs and the cables
What year is this truck? Fuel injected or Carburetor? Hard to know without the year.
Are you missing spark and or fuel? Got both but not at the right time?
You state you replace the manifold. Was it the exhaust manifold or intake manifold?
If it was the intake manifold, I would have to guess you installed the distributor incorrectly. Double check your timing. Position crank at TDC and Position rotor at number 1.
