My car is leaking from underneath, after I put gas in, it will run for a little then it stalls out and leaves a puddle behind. What could be the problem?
Ford Explorer 2003
Keywords:Explorer
What is it leaking?
gas?
oil?
coolant?
What color is it, if you do not know what it is?
Are you putting gas in the throttle body or the gas tank?
The more details you give the closer we can get you to the root of the issue.
If it is leaking gas, I would guess the fuel pressure regulator is leaking and also not allowing enough fuel pressure to fire the fuel injectors. (just a guess at this point)
