Indicators, heater and electric windows all stopped working at same time checked fuses, earth’s and relays all seems OK any ideas?
Keywords:fiesta
You lost connection somewhere. Check your battery terminal connections for any signs of corrosion. Also look for corrosion in the battery cables themselves if any is seen at the battery. Check any inline fusible links.
Done all of that already no visible signs of corrosion on terminals battery polls or cables completely has me stumped only thing to do really is follow the wiring harness and see if anything is amiss
