Home » Car Questions » 05 jeep laredo
05 jeep laredo
I’m installing after market led turn signal light strips that have the switchback capability which turns amber color when the turn signal is initiated and then goes back the normal drl’s after.they work normally fine when the car is off but the car turns on they start to hyperf flash … I’ve heard it’s because of the cold diagnostic system but how do I bypass this
1 thought on “05 jeep laredo”
  1. You will need to contact the aftermarket parts manufacturer and seek technical support.
    If you post the part name and model numbers I will do my best to look that up for you.
