I have 94 Honda accord with a problem that’s sputters when turned one has an acceleration hesitation and when runned for a certain time and turned off won’t crank and no start until cooled down
Keywords:Accord
This is an electrical ignition issue. Failing electronics tend to get worse under heat, this is why after it cools for a bit is able to restart. Replacing the distributor assembly should take care of this issue. Your distributor assembly has all the components built in such as the crank sensor, cam sensor, coil and ignition control module. This can be purchased for around $100. See Image for more Details….
