Home » Car Questions » 1996 chev 1500 5.7
1996 chev 1500 5.7
I just had the intake gasket replaced do to leak now I have extremely low ide
1 thought on “1996 chev 1500 5.7”
  1. You can take it back to whoever worked on it or you can try to clean the throttle body.
    Do not spray into it, Spray starting fluid on a rag and wipe the throat and the edges of the butterfly. This will increase the air flow which will allow a smoother (hopefully a bit higher) idle. As long as the engine does not want to die, a low idle isn’t a bad thing. I think My 2006 Chevy 1500 idles at 450 rpm.
    What RPM is yours idling at?
