Home » Car Questions » 1997 Audi A4 1.8T Quattro
Hi, i have a 97 Audi a4 quttro 1.8t, having some issues. have about 8 codes come up P1127, P0300, P0301, 0302, P0303, P0304, P0455, P0137. the car runs rich and bogs alot especially when starting after it has ran for a minute it tends to start rough and usually die unless i give it some gas. i am assuming those codes go hand in hand with each other. i have replaced spark plugs, replaced 2 old coils, cleaned the MAF, and checked intake for leaks. At this point im sure what to do to solve this issue. Could it just be the O2 sensors?
1 thought on “1997 Audi A4 1.8T Quattro”
  1. Absolutely. Would be a good place to start. However code p0455 is separate as it is an emissions only code and will not cause a misfire. I have provided the code information below.
    P1127 Audi – Long Term Fuel Trim B1 System Too Rich
    Possible causes
    – Faulty HO2S
    – Faulty Mass Air Flow Sensor
    – High fuel pressure
    – Canister purge solenoid stuck open
    – HO2S harness is open or shorted
    – HO2S circuit poor electrical connection
    P0137 – O2 Sensor Circuit Low Voltage Bank 1 Sensor 2
    Possible causes
    – Faulty Rear Heated Oxygen Sensor Bank 1
    – Rear Heated Oxygen Sensor Bank 1 harness is open or shorted
    – Rear Heated Oxygen Sensor Bank 1 circuit poor electrical connection
    – Inappropriate fuel pressure
    – Faulty fuel injectors
    – Intake air leaks may be faulty
    – Exhaust gas leaks
    Replacing the rear O2 Sensor bank 1 usually takes care of the problem.
    P0300 Audi – Random Cylinder Misfire Detected
    P0301, P0302, P0303, P0304 – cylinder 1,2,3,4 Misfire Detected
    Possible causes
    – Faulty spark plug (s)
    – Faulty ignition coil (s)
    – Intake air leak
    – Incorrect fuel pressure
    P0455 Audi – EVAP System Large Leak Detected
    Possible causes
    – Missing or loose fuel cap
    – Incorrect fuel filler cap used
    – Fuel filler cap remains open or fails to close
    – Foreign matter caught in fuel filler cap
    – EVAP canister or fuel tank leaks
    – EVAP system hose leaking
    – Fuel tank leaking
    The P0455 it’s a very common code, because the code is set if the gas cap is loose or missing. Start by tighten the gas cap and clearing the code. In most cases the code can be clear by disconnecting the car battery for about 30 minutes.
