Home » Car Questions » 1999 mazda 626 …6cyl.
my tension pulley goes around but wont move up and down on the bracket behind it…what wrong so I no what part to get..
1 thought on “1999 mazda 626 …6cyl.”
  1. If this is an auto tensioner you are talking about and it will not move(keep tension on the belt) you will need to replace the tensioner, that is what it is called. If it is not an auto tensioner, you have to loosen the bolt in the center of the pulley and move the pulley to tighten it and then re-tighten the bolt.
    Tensioner diagram
