I have no power , I have replaced mas sensor, map sensor, throttle position sensor, crankshaft sensor, idles fine in park, there are no more codes showing up, what else could it be?
what codes did you have to begin with that made you replace all these sensors?
No power possibilities:
1. clogged catalytic converter
2. clogged fuel filter
3. low fuel pressure
4. slipping transmission
5. clogged injectors
6. crank case overfilled
7. poor ignition
8. clogged air flow system
9. failed IAT – Intake Air Temperature Sensor
10. ECM failure
