How can I fix my radiator. It has a small leak. I have replaced tensioner pully heater bypass hoses water pump thermostat and radiator cap. I put some stop leak and it worked for a while over heating again and at this time cannot replace radiator. Will it hurt to add more stop lea?.
2000 Chevy camaro v6
I prefer Bar’s Stop Leak (pelletized only). I have had great success when using it for small leaks including internal head gasket leaks. If it is truly a small leak, this should do the trick. This is temporary and not to thought as a repair.
![](data:image/gif;base64,R0lGODdhAQABAPAAAMPDwwAAACwAAAAAAQABAAACAkQBADs=)
![](data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIxIiBoZWlnaHQ9IjEiIHZpZXdCb3g9IjAgMCAxIDEiPjxyZWN0IHdpZHRoPSIxMDAlIiBoZWlnaHQ9IjEwMCUiIGZpbGw9IiNjZmQ0ZGIiLz48L3N2Zz4=)
Less than $5, Click on image for more Details…
