2000 Saturn LS
I’m having trouble with my car stalling on me. It starts back after about 10-15 minutes.Can you tell me what to do?
1 thought on “2000 Saturn LS”
  1. Most likely cause is a failed ignition control module.
    What to do, would to see what you are missing when it doesn’t start. You want to see if it still has spark and or injector pulse.
    You could try spraying some starting fluid in the air filter to see if it will start and this would tell you if it is fuel related, but don’t think it would be if starts back.
