We just replaced the bad clutch with a new one, and I let it sit Ireland idle for about 10 minutes and it started spit and spudder and then died. It hasn’t run since. What should I do?
Make sure it has gas first.
If there is a check engine light on, have the codes scanned and post the codes below for assistance with those.
Determine what it is not getting. Spark or fuel and injector pulse.
Try spraying some starting fluid int he air filter to see if it tries to run on that. If it does then you know you have a fuel related issue.
No Start Diagnostics
