Home » Car Questions » 2001 Lexus IS300
2001 Lexus IS300
My car misses bad while it idles. I have already changed all plugs and wires and also coils. Sometimes it will idle fine for a day or two than it starts missing again.
2 thoughts on “2001 Lexus IS300”
  1. What if any check engine light codes do you have? Is the check engine light on?
    Could be a sticking fuel injector…..
    Pull all spark plugs and read the plugs, take note to which cylinder the plug came from. Look for a wet or extra black plug. This will narrow down the cylinder location and then concentrate on that cylinder only. May need to perform a compression test.
