car runs great shuts off let sit for day then runs great again till shuts off again usually for about 5 miles. only code I get is multiple misfire. starts and idles fine only shuts off once I start driving it.
Keywords:PT Cruiser
Possible clogged catalytic converter. Checking for back pressure over 3 psi at O2Sensor to confirm. Should be at 1.5 at idle and no more than 3 psi on acceleration.
Is there a rotten egg smell? this would also be common with this situation. Wouls also through up multiple misfire code.
