You will need to have the Air Bag codes scanned and then make the appropriate repair. Could be as simple as a loose ground at a sensor or failed seat belt connection switch. Without the code, you would be guessing.
A scan tool with air bag capabilities must be used to extract the codes. Click on Image for more Details…
