Steering wheel shakes violently, new tires, tie rods, breaks, roters. Doesn’t matter what speed of if I’m applying the break
Keywords:Savava
possibly the new rotors are warped or something was not installed properly. Also the hub bearings could be worn, a common failure part. I would jack the front wheels off the ground and grab the tire and try and move it side to side and up and down and see if something feels loose.
did it do this before all the work?
