Home » Car Questions » 2005 Dodge Grand Caravan
How many windshield washer pumps are on this vehicle and where are they located?
1 thought on “2005 Dodge Grand Caravan”
  1. One washer pump Only according to wiring diagram in the manual. Labor time about 1/2 hour. Part : less than $15.
    Follow image for more Details…
    Washer Pump Replacement
    REMOVAL
    1.Disconnect and isolate the battery negative cable.
    2.Hoist and support vehicle on hoist or jack stands.
    3.If necessary, remove the right front wheel and tire assembly
    4.Disconnect the right front wheelhouse splash shield and move aside
    5.Drain washer fluid from the reservoir and into a suitable clean container. This can be done by disconnecting the windshield washer hose from the front (outboard) washer pump port and allowing the washer fluid to drain into a container through a temporary jumper hose connected to the front washer pump port.
    6.Disconnect the electrical body harness connectors to the washer pump motor. Slide the red lock on the connector to the release position, then, depress the black tab and pull the connector off the pump.
    7.Remove pump from reservoir by pulling pump upper retention tab away from reservoir cavity and then lifting pump up from mounting grommet. Do not damage reservoir/pump sealing surface or puncture reservoir during removal.
    8.Remove pump grommet and discard.
    INSTALLATION
    1.Use new grommet when installing a new pump assembly.
    2.Assure pump upper retention tab is pressed into reservoir slot and that pump is rotated flat against the reservoir and that pump connector is facing up in the fully seated position. Assure the pump is aligned to and fully seated in the reservoir cavity.
    3.Connect the electrical body harness connectors to the washer pump motor. Slide the red lock on the connector to the closed or locked position.
    4.Assure that washer hose is properly routed to prevent pinching and possible inoperative washers.
    5.Connect the left right front wheelhouse splash shield and move aside
    6.Install the right front wheel and tire assembly
    7.lower vehicle from hoist or jack stands
    8.Connect the battery negative cable.
    9.Verify system operation.
