Home » Car Questions » 2005 Ford Escape XLT
Have a bad vibration when car gets to about 40 mph, when the overdrive is taken off, the vibration diminishes but doesn’t completely go away.  Motor mounts and transmission mounts have been replaced.  Have had numerous people look at it and someone suggested going to Ford and asking for a transmission additive for a torque converter vibration??…..  Is this just added to the fluid or does the trans fluid have to be drained and replaced?
1 thought on “2005 Ford Escape XLT”
  1. What you need to add is called “shutter fixx”. This is an additive that should take care of the issue you are having. You just add it to what is already there. Simple and easy, you can do this yourself. I have used this myself many times with great success over the years.
    Follow image for more Details…
