Home » Car Questions » 2006 pontiac grand prix 3.8
the car shuts down while driving it and after sitting 5 minutes it will crank back up.,
1 thought on “2006 pontiac grand prix 3.8”
  1. Is the check engine light on? if so, have the codes scanned, this can be done at just about any local parts store for free and then post the codes below in the comments.
    The most common reason for the problem you are describing would be a failing ignition control module.
