I need to replace the power steering hose that runs from the reservoir to the rack. However when I’m searching for the part there are more than one hose, pressure hose and return hose, not sure which one it is.
The hose attached to the reservoir is the return hose, the one attached to the pump is the pressure hose. The Reservoir is not under pressure, this is how you are able to check the fluid level while the engine is running.
