I just reinstalled the dash and when I turn the ignition switch to the start position nothing happens. With key in the position just before the start position, normal dash warning lights come on and then go off, except the Anti-Theft System light stays on with rapid blinking. I rechecked the electrical connectors.
Keywords:Focus
First make sure battery is fully charged.
Disconnect battery, put ignition key in the “ON” position and reconnect battery. Move ignition key form “ON” to “START”. This should reset the anti-theft if that is the issue.
Make sure the shifter is going into PARK.
