Home » Car Questions » 95 Geo Prizm
95 Geo Prizm
I put in a new battery but car still won’t start. It’s like its getting no gas
1 thought on “95 Geo Prizm”
  1. Try spraying some starting fluid in the air filter, if it tries to start then you know your thoughts were right on the money. You may need to replace the fuel pump, check for injector pulse first and the ECM fuse if none is found.
