Home » Car Questions » Chrysler 2007 Sebring 4 cylinder
I am having a check engine problem. I am getting a service fault code of p2017 Intake manifold runner position sensor/switch circuit high bank 1. I have changed the intake manifold valve actuator but the engine light is still on.
1 thought on “Chrysler 2007 Sebring 4 cylinder”
  1. If you haven’t tried to clear the codes and then test, you may want to disconnect the battery for 10 minutes and then reconnect and test it to make sure the light comes back on. If it does, refer to the possible causes listed below.
    P2017 Chrysler – Intake Manifold Runner Position Sensor/Switch Circuit High Bank 1
    Possible causes
    – Manifold flow valve harness is open or shorted
    – Manifold flow valve circuit poor electrical connection
    – Faulty Manifold flow valve
    – Intake manifold
    – Faulty Powertrain Control Module (PCM)
