If the tire pressure in my car is low, Is it possible to put a hole in the transmission case by going over railroad tracks, potholes or speed bumps(as a reasonable speed)? I didn’t run over anything other then that, that I can think of. Any other causes for this to happen?
If your transmission hits anything hard at anytime even if your tires are not low, it can damage it. The transmission case is made out of aluminum or softer material and can easily be damaged if hit even at 5 mph. So, is it possible? YES. I am sure you would have felt it as well.
Other causes are Hot Rodding it. Rev it to the moon and dump the clutch (if manual transmission)
