engine noise, like a humming while driving in any gear speeds up and down with the engine revs, but goes away altogether when you depress the clutch ? iv had a new clutch a year ago and also a new alt in it in the last few weeks
If the noise goes away when you press in the clutch pedal, This would be the throwout bearing making the noise. The bearing is under pressure when the clutch pedal is pushed in and relieved of pressure when not.
Diagram is for description only, this is not a diagram of your specific vehicle.
