Home » Car Questions » 1975 ford 6 cyl .
1975 ford 6 cyl .
has new rebuild water goes into the base. water drops while setting.
1 thought on “1975 ford 6 cyl .”
  1. I am going to assume that you are calling the oil pan the “base” ?
    Water is leaking into the oil pan when it just sets still. This can only happen if there is a bad gasket(seal) or a crack in the intake or block.
    feel free to clarify in the comments below.
