I have switched all 3 fuel filters car still will run a while fine then it is like the gas don’t come threw it quit pumping gas my sending unit one of the plugs on it broke so we cut the plug and put the wires back in I think it the fuel pump or sending unit
1991 Subaru
When it is acting like gas won’t come through, try spraying some starting fluid into the air filter and see if it will allow it to rev up like normal. If it does, then you know for sure it is fuel related.
If it boggs down, you know it is getting plenty of fuel and that it is your electronics breaking down…would be my guess and I would lean toward the ignition control module. This tends to happen once they warm up and work fine once cooled back down or cold(first start of the day)
