I can’t get the caliper back onto the rotor. There is no clip on the inside brake pad. Anybody know what I can do to get the caliper on?
If the pads will not slide over the rotor, you will need to press the caliper piston all the way in and then install.
Step by Step Brake pad replacement with Illustrations
