my engine is blown. I found an engine off of a 2005 with a manual transmission will this work for me
Home » Car Questions » 1995 pontiac sunfire automatic transmission
Keywords:Sunfire
The transmission type will not make a difference. You should be able to use the “long block” portion either way as long as it is the same engine. In 1995 the Pontiac Sunfire came with a 2.3L and a 2.2L engine. Make sure you know which one you have.
