Home » Car Questions » 1998 plymouth grand voyager
I have a missfire and battery light that came on whats the problem to fix it
1 thought on “1998 plymouth grand voyager”
  1. The battery light indicates the Alternator is no longer charging the battery. Most likely you will need to replace the battery.
    When the alternator is not charging the car runs off the battery alone and when it starts to get weak the engine will no longer perform correctly as it relies on many electronic sensors to run.
