Home » Car Questions » 1998 taurus 3.0 V 6
1998 taurus 3.0 V 6
engine start to miss as soon is shifted to drive gear is ok if keep in neutral
2 thoughts on “1998 taurus 3.0 V 6”
  1. If there is a true engine miss the check engine light will come on. Once this has happened the code will give us the exact location of the misfire. At that point we will know which cylinder to replace the ignition coil.
