Home » Car Questions » 1999 Toyota Camry
1999 Toyota Camry
The break line busted on my 1999 Toyota Camry and I replaced the break line and caliper. After that it happened on the other side. Is my master cylinder going bad?
1 thought on “1999 Toyota Camry”
  1. No, your hoses have gone bad. To be on the safe side. Have the brake fluid flushed and replaced with fresh brake fluid. This should prolong the life of the new hoses and help prevent it from happening again if it was caused by contaminated fluid.
    A bad master cylinder will not cause brake caliper hoses to go bad.
