Home » Car Questions » 2000 dodge stratus
2000 dodge stratus
My car won’t start.I put new fuel filter, plugs. It has plenty of cranking power, it just won’t turn over. I also replaced start relay. I’m lost any suggestions. I’m trying to avoid bringing it to a shop thanks in advance
1 thought on “2000 dodge stratus”
  1. Does it crank but does not start? Starter spins and engine turns over but does not start.
    Does it not crank(turnover) at all?
    You need to determine if you are not getting spark or fuel or both. If you have spark you can try starting fluid in the air filter and if it tries to start you know it is fuel related.
    No Start Diagnostics.
