Home » Car Questions » 2001 chevy tahoe 4×4 5.3 engine
changed speed sensor on transmission and now it wont do anything. acts like i don t have a battery in it. what did i do wrong
1 thought on “2001 chevy tahoe 4×4 5.3 engine”
  1. Probably nothing at all. Maybe left the hood up or left the key on and it drained the battery. Charge the battery and insure the terminal connections are good and clean so they make good contact.
    If this doesn’t work, you will need to check for battery voltage at the “s” terminal on the starter while someone holds the key in the “start” position.
