Home » Car Questions » 2002 OLDS INTRIQUE
2002 OLDS INTRIQUE
(P0410) where can i find both diverter valves
1 thought on “2002 OLDS INTRIQUE”
  1. P0410 Oldsmobile – Secondary Air Injection System Malfunction
    Possible causes
    – Faulty Vacuum hoses damaged
    – Faulty Air Pump inoperative
    – Air bypass solenoid harness is open or shorted
    – Air bypass solenoid circuit poor electrical connection
    – Air bypass solenoid leaking/blocked or stuck open/closed
    – Air diverter valve leaking/blocked or stuck open/closed
    It’s on the back wall under the hood on the drivers side.
    diverter valve location diagram 2002 olds intrigue
