P0410 Oldsmobile – Secondary Air Injection System Malfunction
Possible causes
– Faulty Vacuum hoses damaged
– Faulty Air Pump inoperative
– Air bypass solenoid harness is open or shorted
– Air bypass solenoid circuit poor electrical connection
– Air bypass solenoid leaking/blocked or stuck open/closed
– Air diverter valve leaking/blocked or stuck open/closed
It’s on the back wall under the hood on the drivers side.
Possible causes
