I just replace the transmission in my truck and now it wont start. Replaced the starter and neutral safety switch and she still wont fire or even try to fire up. Anyone have any suggestions?
Recheck your Ground wire.
Does it crank but does not start? Starter spins and engine turns over but does not start.
Does it not crank(turnover) at all?
You need to determine if you are not getting spark or fuel or both. If you have spark you can try starting fluid in the air filter and if it tries to start you know it is fuel related.
No Start Diagnostics.
