Hi – the driver’s side window randomly retracts without pressing the down-window button. Not only that, but it retracts with the engine OFF! That’s right, we’ve turned the engine off, removed the key and watched the window roll down.
2007 Toyota Highlander Limited
Keywords:Highlander
I have done a little research on this and have found that it is becoming a common problem with this vehicle. 2 Solutions have been found. One was to replace the Master Control Switch. The other found they couldn’t open there doors with the key and that lead them to discover,after removing the door panel, that a little clip that goes from the drivers side door lock to the master control had come off. Once that was reconnected everything started working as it should.
![2007 Toyota Highlander Drivers side window wiring diagram](data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIzOTAiIGhlaWdodD0iNjE3IiB2aWV3Qm94PSIwIDAgMzkwIDYxNyI+PHJlY3Qgd2lkdGg9IjEwMCUiIGhlaWdodD0iMTAwJSIgZmlsbD0iI2NmZDRkYiIvPjwvc3ZnPg==)
Thanks for your detailed reply.
