My Car has a C1956 fault and it tells me that the brake pressure sensor is bad and I can not find it most pictures show it screwed into the master cylinder and there is nothing there. I have the 3.5 front wheel drive.
Keywords:Taurus
C1956 – Steering Angle Sensor Circuit Failure
It sounds like you have a faulty power steering pressure switch. Make sure it is connected and if it is I would replace it and that should take care of your problem
In my research a low or faulty battery can throw this code just from not having sufficient voltage after initial start up. If you haven’t replaced the battery or it has been over 3 years, i would recommend replacing it anyway.
