van will not shift into D, 3rd or 2nd gear but will move in 1st and reverse. What could the problem be? does it need a transmission replacement?
Keywords:Uplander
If the transmission fluid has a dark burnt color, then you are probably looking at a rebuild or replacement. If the transmission color is nice and bright redish/pink, then you are looking at shift solenoids or valve body as a worse case.
Transmission Troubleshooting
