Home » Car Questions » chevy s10 zr5 truck
chevy s10 zr5 truck
my chevy has 4.3 engine in it and i get the code po300 so what would your suggestion in finding the right problem
1 thought on “chevy s10 zr5 truck”
  1. P0300 Chevrolet – Cylinder Misfire Detected Random Cylinders
    The P0300 code means that a cylinder(s) is misfiring or is randomly misfiring. Start by checking for intake leaks, intake gaskets are common caused of multi-cylinder misfiring. If no leak are found the next step is to replace the spark plugs. If the problem persist more tests needs to be done to diagnose problem, see “Possible Causes”.
    Possible causes
    – Faulty spark plug (s)
    – Faulty ignition coil (s)
    – Intake air leak
    – Incorrect fuel pressure
