There are a few things that are sure signs of a bad brake caliper.
One is if you find it leaking fluid from around the caliper piston. Another way is if you remove the caliper hose and the piston will not compress inward, this is a Frozen Caliper. The other would be if it has damage such as a broken mounting or cracked housing.
