Home » Car Questions » jaguar xjs v12 1989
jaguar xjs v12 1989
engine will not fire, have emptied fuel tank cleaned new fuel added,fuel 2 rail ok,spark 2 plugs ok, spark 2 injectors ok,gave a small squite of start u basted and fired .
1 thought on “jaguar xjs v12 1989”
  1. You need to check fuel pressure and for injector pulse. You need to see at least 30 psi.Not enough fuel pressure, injectors will not fire(spray). And you need to see the injectors pulsing. If the injectors are not turning on and off then it won’t matter if you have good fuel pressure. Use a tester to confirm this.
