Home » Car Questions » nissan 2003 Sentra
nissan 2003 Sentra
When I get in my car and the car interior is hot. The power windows do not work. After I use the fan or ac to cool the inside of the car they work. What is wrong, or how do I fix?
1 thought on “nissan 2003 Sentra”
  1. I would have to say this is just a coincidence but there is the possibility of a connection issue here. You will need to determine if the master Window control panel has power when it is not working. If it does not you will have to trace the wiring to see where it is lost and repair it. If it does, you will need to determine if there is power coming from the control panel… if not, rule out bad connections and replace control panel. If you do have power leaving the control panel and reaching the window motor… rule out bad connection and replace window motor.
    How to use a Multi-Meter
