Home » Car Questions » Toyota Premio D4 3S-FSE Engine 1999
My car had a misfire, rough idling and unstable rmp plus stalling. i took it to the workshop and they sealed the EGR which helped. The misfire reduced significantly and idling smoothed out however the rmp instability is still there…sometimes drops too low to about 250 with vibration this is however intermittent. to raise the rmp i need to step on the accelerator and it improves. Stalling has happened only once since. What could be the problem?
1 thought on “Toyota Premio D4 3S-FSE Engine 1999”
  1. I would start by cleaning the throat of the throttle body with brake wash on a rag. Also clean the edges of the throttle butterfly. this will allow a significant increase in the amount of air to flow. Next, cleaning the fuel injectors would also help.
    Of course, if there is a check engine light on, pull the codes and post them below in the comments.
