My Honda seems to have a hard time shifting gears but it doesn’t do it all the time the longer it sits the better it does iv done a complete trans flush help ed for like three days then wood shift at all after about a week of sitting it’s fine again still has problems from second to third but driveable check engine light came on but where it sat the battery went dead and now I can’t get it to come back on
Keywords:civic
The codes should be stored and will need to be extracted, You may want to have a transmission shop pull the codes as they should be better equipped to explain the codes and what it may take to fix the problem.
The good news is, since it did spit out a code the issue should be electronic and should not require a complete rebuild.
