Home » Car Questions » 1986 Toyota Camry 2.0 gas engine
I started the car and started to drive. As the temptemperature gauge started to rise above cold, I noticed that it would fluctuate when I hit the gas. When I press on the gas the temperature gauge drops to cold and as I let off the gas it rises back to normal. The same thing when I shift….
After I drove about 14 miles the car over heated. The over flow was full.
I replaced the radiator and thermostat. Could the cause of this be a faulty temperature sensor? Please help.
1 thought on “1986 Toyota Camry 2.0 gas engine”
