Home » Car Questions » 1990 ford ranger
1990 ford ranger
i have a 90 ford ranger truck.my power steering pump is leaking fluid aroung the metal line that screws into the pump.i can’t break the tap loose. is there anything i can put on the threads to stop it from leaking? please help
1 thought on “1990 ford ranger”
  1. this the pressure line it is a swivel fitting with a nylon gasket or 0 ring fitting. need to replace it . if you have go ahead cut line so you can put socket on tap to remove it .
