Home » Car Questions » 1995 Mazda 626
1995 Mazda 626
My car acts like it doesn’t want to go over 35 mph, and it won’t go past 3000 rpm. Sometimes it acts like I’m not pushing on the gas pedal. Then sometimes the rpm will keep going up, but the speed of the car will continue to reduce. While the car is in neutral or park, the rpm’s won’t go past 2000. After I get it about a mile down the road it will start going faster.
1 thought on “1995 Mazda 626”
  1. The engine not being able to rev in park or neutral is normal. This is from a built in rev limiter that prevents the consumer from damaging the engine. However the issue you are having sounds like the transmission slipping. First thing to do would be to check your transmission fluid level.
    How to check your fluid levels
